?????????? Don't know what this means.
I'm assuming like many forums this forum let's you know if someone has posted as you were typing your reply. And it allows you to view it before you reply so you can alter your response if needed.
As he was replying someone else did saying something similar to him and he never was prompted that another reply had been posted whe he was typing his.
Pools 1/3 empty. Cmon sump pump you can do it!
yep, resp has it right; Ben posted while I was typing, so I went back and edited; but I know in the past it's stopped and given me the warning prior to posting my message...
Pools 2/3 drained and I'm glad I made this decision. The pool cover came off during the winter and there is a ton of debris on the bottom. Leaves and dirt and etc. I'm gonna scoop it all out, give the pool a nice wall and floor sweeping and refill immediately
Quick update. Pool is cleaned and refilling. Taylor pool kit is here and once it's filled I'll adjust the levels and post readings. Thx all
