Any updates?
Any updates?
Pool looks like first pic, BLUE. Used flocculent and vacuumed to waste Fri. & Sat. Fill water now softened. Cleared Fri. and sparkling by Sun. Labor Day at the pool planned as supposed to be 93 here today. Old bathing suits as running FC > 5, < 10 with CC 0.4. Phosphate testing kit should arrive tomorrow. I will post level.
Thanks again for your support!
The pool remains blue and clear. Did use flocculent again and vacuumed to waste. Very little, but some, algae fell out and was vacuumed out of pool.
Phosphate kit arrived, > 1000 ppb in the pool. Ground water must also have phosphates as "softened well water" also has > 1000 ppb. Plan to control algae with FC for the remainder of the month as I am reluctant to cloud pool with treatment since we can finally use the pool. Seems like it will be a vicious cycle with the source water as it is.
Try using very small doses of the phosphate remover, added at night. Make sure the pump is running. In at least some cases, the pool will clear fully overnight. If you use a small dose, even if this doesn't happen there won't be enough cloudiness to be an issue.
Caution: phosphate remover should ONLY be added when the filter is clean enough to allow the pool to operate for 3 - 4 days without cleaning the filter. Otherwise, you'll likely lose some of the phosphate remover uselessly.
See you on-line. Any updates?
Closed and covered pool last week-end. Water was crystal clear. I spent a couple weeks getting the phosphates out before I covered it. Looking forward to an easier season next year. Thanks for all the assistance.
You had a tough go this year. Congrats on closing clear! Open early and let us know how it goes!
PoolDoc:
This is my second year of having to do the ascorbic acid treatment. Works like a charm. I stayed stain free until late August last year--Im sure its my well water doing me in.
My question is-can I use the calcium hypochlorite tabs with my DE filter? I'd like to try and get the iron out of the water. I do use the Culator pack in the skimmer.
Thanks for your time.
Tony
Hey! Your question is very specialized and belongs in it's own thread.
Unfortunately, PoolDoc is the Guru on this issue and is away from the forum right now.
I suggest that you start a new thread. Click "Post New Thread" here: http://www.poolforum.com/pf2/forumdi...erals-amp-Ions
