all they had were strips and I miss read it it is at 50ppm the bleach seems to be working I have gone from a very green pool to a light green so we r making progress my ph was high so I added acid I will test agine tomorrow.
Keep hitting it with bleach. As often as you can per day, test and add enough bleach to get it back to shock level.
Also, you don't say what your readings are but, if your chlorine level is higher than 10, your pH test will falsely show higher pH than you actually have. So, don't test pH or add muriatic acid unless your cl is below 10ppm.
