Re: DE in a sand filter???
Not to sound to ignorant but when you put the DE in the skimmer what setting is the filter on? If it is on filtering the DE would be pushed out into the pool. Do you leave it on backwash? For how long?
You leave it set on filter. It catches at the top of the sand and does not return to the pool unless you have a filter problem.
You only backwash when you want to clean your filter. If you backwash after you've added DE, it rinses out and you have to re-add it.
Originally Posted by CarlD
Have you TRIED the DE-in-the-Sand method? I have no experience with Zeolite but I gather it's primarily an ammonia remover (I could be wrong).
Or maybe it puts ammonia IN your water--something that I think is VERY bad to mix with chlorine. Remember: I know little about Zeolite.
Surely there is NO way that Zeolite is cheaper than sand and DE--is there?
Backwashing every 2 weeks (about my average) is not what I consider an arduous task. If I ever run a hard pipe into the storm sewer it will be even easier--I won't even have to roll out and roll up the B/W hose--just flip a lever and watch the sight glass....
Still, do you have DIRECT experience that Zeolite works better than DE in Sand? Or are you just guessing because Zeolite has done well for you?
My water is sparkling clear too--even at night with the lights on--and it wasn't before I started using Poconos's DE trick. It was clear, but not sparkling.
I recommend it because it has worked so well for us. We had no water available to us other than from a very hard water iron rich well. We wanted the maximum filtration we could get from the filter with the least amount of maintanance. We got that with the sand filter and Zeolite.
We knew the pool was going to get it's share of air borne debris from the various trees in the area. We also wanted to put as little effort as possible into pool maint. We got that from the SWG, Poolskim, Pool Rover, sand filter with Zeolite. I've had to backwash the filter one time since the pool was installed in early March.
I don't know that you can justify the cost over DE in sand. However here are some things to consider.
1. You only use have as much Zeolite as you would sand.
2. You backwash much less frequently which conserves water and chemicals and is easier on the enviornment.
3. Zeolite is a natural bio-degradable medium so can be disposed of safely which includes using it in your garden.
4. The reduced labor and maint. hours should add up to some value.
5. Zeolite is renewable. When the filtration qualities diminish you recharge the medium with a salt solution. It is "supposed" to outlast sand many times over. Our neighbor has a never ending sand pile as he replaces it every year (softswim user).
6. I don't think a cost of $40.00 for a 50lb bag is all that expensive comparied to the per ounce per pound cost of other pool chemical products. We needed 175 lbs for a total cost of $160.00 with some left over.
Just some things to consider.
Originally Posted by waterbear
Zeolite seems to be the new 'miracle product' for pools. It has been used in aquarium filtration for years, primarily for it's ammonia scavaging ablility. In aquariums it has not proven to be a better mechanical filter than sand.
Carl, the trick with DE in a sand filter has been around for a long time. I first heard about it about 20 years ago from my neighbor with a pool (I didn't own a pool back then). He learned it from his pool service guy!
It's funny how whenever someone posts information about a product that is somewhat out of the norm the naysayers come out in great numbers. I'm speaking from actual experience in using the product.
Do the research & look at the test results. I think you will find that indeed Zeolite does provide equal to or better filtration properties than DE. It's less maint and is easier on the envionrment.
I have large aquariums but your talking about two completely different environments with different pump and filter equipment exposed to different elements under different conditions. Lets compare apples to apples.
All I can tell you is I've had no iron staining, algea or any other water treatment issues. I love my almost maint free pool.
Now I figured it out. The way my pool was plumbed was wrong. I didn't think it looked right last night so I called the store and they said it was reversed. I have water coming out of my skimmer and water going in at the eye. The installer is on his way back to fix it. Duh-you'd think they'd know how to plumb the pump when this is all they do in the summer. Denise
If you add DE before they get there, add it through the eye :)
Zeolite can remove heavy metals (including calcium and iron) from the water in much the same way it removes ammonia (and in fact is sometimes used in water softener units as the ion exhange resin) but it is not nearly as effective as other water softening resins and if the concentrations are high it will require regeneration once it's capacity has been reached ...see below about regeneration of zeolite. Also water softeners are regenerated with the brine solution ususally at least a few times a week so this ability will quickly diminish!
That is by weight, not by volume. It weighs about half as much as sand. The price per pound is much higher than sand. A 50 lb bag of sand sells for about $6 so 6 bags would be 300 lbs and costs $36. A 150 lb bag of Zeobrite (equivalent to 300lbs of sand) sells for about $75 dollars...more than double the price for the same amount needed!
This is probably true since the rough surface of zeolite can trap more dirt than the smooth surface of sand. One plus for zeolite. However the grains are actually up to 3X larger than sand grains (up to 1.5 mm while sand is about .5 mm) and that will reduce the mechanical filtering ability so you might only be breaking even here.
Last time I checked DE was also a natural medium. Zeolite does not biodegrade. It is a mined mineral and is a hydrated (containing water) alumino-silicate oxide (contains both aluminum and silicon). Sand is silicon dioxide (silica). DE is the fossilized shells of prehistoric freshwater and marine organisms and is primaily silicon dioxide(silica) with a smaller amount of aluminum dioxide and other minerals present. All three are mined. Non of them biodegrade. All of them can be mixed into your garden but all they are basically a form of sand (silica).
remains to be seen. With the necessity of 'recharging' the zeolite yearly (for chlorine pools) with an acidic brine solution it might be more labor than sand.
Zeolites main advantage is the ability to adsorb (not absorb!) ammonia compounds. It has been used for aquarium filtraton for this reason for many years. It acts like an ion exchange resin in your water softener and is functioning as a chemical and not mechanical filter medium in this respect by trapping ammonium ions. When it cannot adsorb any more it can be regenerated with an acidic brine solution (concentrated salt solution and acid). As far as cleaning it of particulate matter (mechanical filtration) that is what backwashing does so it is no different than sand here. Plus you have the added step of 'recharging it yearly and have the brine solution to dispose of....good way to kill the grass!
Can't compare biguind (SoftSwim) to chlorine here. Even on the Zeobrite website they recommend cleaning the zeolite medium MONTHY with the above cleaning solution when using bigiunide. The makers of the various biguinde systems (Baquacil, SoftSwim, Revacil) also recommend monthy cleaning of sand when used with their systems and yearly reppplacement. Seems like it's exactly the same. It will still probably require yearly replacement (or perhaps more often) just like sand since since biguinide gunks up and ruins filter material and the 'pores in the zeolite will certainly get gunked up fast.
Sand at $6/50 lb bag would have cost you $24. Even if you paid a premium price of $12/50 lb bag of sand that is still less than $50 total! Think of all the bleach you could have bought with the left over $100-$125 dollars!
Just a few more things to consider!
Comments have been made in this thread that you can reduce the number of times backwashing is required.
Think about this. Your systems starts up and your skimmer collects a handfull of dead and drowning insects. Earthworms fall into the pool and settle out on the bottom and get sucked into the bottom drain. A lb. of pollen drifts onto the surface and is sucked into the skimmer. A bunch of swimmers jump in an dead skin sloughs off. Some feces are washed out the swim trunks. Hair, grass etc.
You all know the routine. ( or should )
So it goes into you filter and is filtered out. Out of what ? Out of sight and nothing more.
And that's where it ends until you flush it out with a backwash. All that junk from March, ... it's now July, is still in your pool water. In fact much of it is force fed pool water while ever the pump is running.
4 month old dead rotting earthworms ... still in the pool water. Just out of sight.
Now if you're real good about your chlorine and CC levels, it is eventually going to be oxodized. But any bit of a slip up in your routine and you have be saving up all this stuff to make a biological time bomb.
I think it is foolhardy to leave that junk in you system and think you are smart by saving 5 minutes to backwash and a hundred gallons of water.
Just my opinion. Comments and critique invited.
I'm also a big believer in backwashing. I don't mind having to re-add the DE or replace some water and sequestering agent. I just think it's a much cleaner pool when the filter material is as clean as it can be. I don't have a bottom drain though so my worms and stuff get emptied when I vac.
I backwash every time I vacuum. Before I do it I fill the pool til it is a bit high then vac, then backwash. I have an 18' pool, and it gets low when I BW if I don't fill it up first sometimes.
