autopilot or aquarite?
I am trying to decide between the autopilot and aquarite setups for my pool. I like the idea of the integrated automation of the autopilot (I would love for the system to automatically turn on the pool pumps when needed to sanitize, etc...), but I have a concern as to their pre-assembled manifold. I have not seen in their manuals or mentioned anywhere else if the manifold can be mounted vertically? Does anyone know if manifold orientation makes a difference on that unit? The aquarite manual, on the other hand, shows vertical installation as being possible (which is the only way I can do it on my setup without getting super crazy on the piping)? This alone may make the decision for me. Thanks.
Regards,
Mark
EDIT: I'm thinking I wasn't clear enough so I will try and explain a little better. My return line exits the top of my Hayward EC65 and goes about 3 inches into a coupling (so I can easily remove the filter from the system) and then takes a 90 degree turn and goes straight down into the ground. I can only place the generator cell or manifold in that downward piping. I hope that helps explain a little better in case I wasn't clear before.
Beautye,
You're fine installing the manifold assembly this way. Hope this helps you with your decision and thanks for considering AutoPilot.
Not that I am doubting you, but after I posted my question here I did some more research and came across this statement in the "Digital Total Control Manual.pdf"
The manifold/cell should be installed in a vertical orientation as illustrated in the picture below. This orientation
prevents hazardous gas buildup in the system if the flow switch should fail to detect insufficient flow.
http://home.comcast.net/%7Eflyinz28/manifold.JPG
I definitely don't want to create a hazardous situation here. Still stand by your statement that I can install it in a vertical running pipe? Thanks for your assistance.
Regards,
Mark
Definately. We want to avoid mounting the manifold upside down (with the manifold loop below the horizontal base. You can mount it vertically as you described.
Great! Thank you. I appreciate your help.
Regards,
Mark
That manifold is one of the things that sold me on the Autopilot. I like the idea of the check valve, on my system it seems to bleed off a lot of excess pressure.
Without it I am not sure how you could regulate the water pressure through the cell.
Anyway, good luck with your decision. Whichever way you go you will be happy with your SWG
