Thanks Aylad. That is very helpful. I cranked up the chlorine even higher last night. I had a small drop overnight from 36 to 35.5 this morning. CC is .5. Ph went up again, so your info is very helpful. Thanks.
Happy to help. If you're no longer losing more than 1 ppm of chlorine overnight, then you should be about ready to close :)
Update: After the algae was conquered, the pool took a long time to clear (even with vacuuming to waste). Putting some DE in the skimmer last weekend really helped (a tip I found on this site). I am happy to report that almost 2 months to the day after I bought the house and inherited this pool, I can finally see the drain. The pool store is closing my pool on Monday. I am looking forward to eventually doing that myself, along with doing the opening. But, I want to see it done first (I learn better that way). Thanks for your help.
Do yourself a favor and videotape (or at least audiotape and write down steps) the closing. It's amazing what details you can forget in a year's time, and forgetting steps can be disastrous :)
