Re: FC and TC Too High and won't come down
Ok.
+ CYA>100 => keep your chlorine at 7 ppm or above.
+ Do NOT add any alkalinity plus or calcium hardness increase type products.
+ Give us an inventory on what chemicals you have left. I assume you have, or will return the tabs. You can use the 4n1, but because of the alum you may want to add it via your skimmer. Just make 110% sure that there are NO tabs in the skimmer, a feeder or anywhere else where the shock can touch them. Just make sure your chlorine stays above 7 ppm.
+ Do you have access to pool store liquid chlorine (commercial bleach) or cal hypo in a 50 or 100lb container?
By the way, having a CC reading of 0 is good! That is what you want!
