Re: new user, old pool, trouble with algae
Well I drained, refilled, and have been holding water for 36 hours, so I hope that means it was successful. I worked very quickly, left about 18" of water in the deep end to hold the liner down and immediately started refilling with three hoses pumping water into the pool, got it filled back up in about 24 hours. Added bleach as I went, as the little bit of old water that got mixed with the fresh was pretty nasty. I untucked the liner at the point where the shallow end starts getting deep, and tucked the hose from my shop vac in there to help hold the liner until water reached about 4" in the shallow end. Funny thing is, about 3 years ago, we didn't close properly and decided to drain/refill but didn't know any better that it could ruin a vinyl liner, that's when I got a couple wrinkles in the shallow end. This time, working quick and using the shop vac, I was able to drain/refill without adding any more wrinkles. I know that may have just been dumb luck on my part. I do appreciate your advice and took the warnings seriously, but I really wanted to get off to a fresh start after discovering this forum. From now on, I'm not putting anything in my pool unless I know exactly what it is and what it will do!!
Oh, and the little bit of green that was left from the old water quickly disappeared, water is blue, a little cloudy (can see bottom of shallow end but not deep end), but overall MUCH better. My test results this morning showed my FC and TC right at 8.0 ppm, ph 7.8, TA 80, and CYA at 30. I'm using my remaining trichlor pucks from the pool store until CYA gets to about 50, then it's all BBB from here on out. The cloudiness seems to be improving, but I've got a skimmer sock in there to help anyway. I've been reading lots of other threads on here over the past week, and feel like I have a better understanding of pool chemistry and operations, but I'm sure I'll be back with more questions over the summer. So glad I don't have to go back to the pool store and empty my wallet again!!!
Sounds like you're moving toward a good pool summer!
