Reporting my results.....pool still is cloudy. Not as cloudy as when I first posted but about the same as after I started with the DE. I can see the bottom but it is not sparkling clear. I will email a photo.
Last night when I tested, the FC was a little over 10 but the CC was at .6 so I added the balance of the gallon of 12.5 liquid chlorine. Let the pool sit overnight without pump running. Here are my readings this morning:
FC. 14.2
CC: .2
PH: 7.2
TA: 120
CYA: ~35 (between the 30 and 40 mark)
CH: non existent - would not turn red. I usually do not test for this with my vinyl pool but it seems odd to me that this has gone down.
Not sure if it matters but it has been rainy the past couple of days.
I ordered the GLB product you linked to above. It is not here yet, will probably arrive in a couple of days. I can keep filtering through the DE, which seemed to help a little, but for now pump is still off until I come back later to read.
As I said, I bought a smaller pump but won't be able to install that for a couple of weeks as my husband is out of town on business and I can't do it alone. I suppose I could add in a valve between pump and filter...but would need to go to pool store to get those items.
