hsdancer
-My understanding is that the only way the copper bonding loop ever connects electrically to the pool water is through the pool pump.
I will try to attach a picture of the set up (no luck).
Again thanks for all the help. I will be performing a few more measurements this weekend to see if I can isolate the problem. I thought that the 180' of bonding wire would also serve as a ground, but since it lies mostly in sand, that may not be the case. I like the idea of a second bonding loop and an additional copper ground....
