Re: Yay!!!New pool!!!
Have ordered the K-2006 and it will arrive 7/25-7/30. Tabs are 99.9% tabs so what do I get for stabilizer and where do I get it? FC....I'm assuming (since I'm new to all this) that that is Free Chlorine and have no idea what the CYA levels are so I don't know if you're telling me Yes, it's safe for swimming or No, it's not. I'm sorry I haven't learned all the lingo yet. I've been reading as many previous posts as possible to learn as fast as I can. Please bear with me. I will have Muriatic acid by this evening and need to know how much to add for a 20' round x 48" deep vinyl pool, to lower the ph. Water is still crystal clear and very inviting and I can't wait (since temps are in the 100s today) to get in there.
Have you used any of the tabs? How many.
I don't know how you get pH of 8.5 - does your test kit go that high? Is that the top of the kit?
Nope, it doesn't. I was reading the thing wrong. Just took a (with my glasses on) test after adding 2 gallons of Clorox this morning and got ph 7.8 and Cl 2. It was at the top earlier this morning at (or above) 8.2. Sorry for the incorrect test results...I know that doesn't help you help me and will be more mindful in the future.
I put a tab in every day for the past 3 days and they didn't dissolve enough to change the readings. They are the 99% tabs from Sam's. The test results were still very low so that's when I poured the 2 gallons of Clorox in this morning.
Also, just be aware that when your chlorine is above 5ppm, your pH results will be invalid. (Above 10ppm with a Taylor kit.) To get an accurate reading with high chlorine you can take equals parts of pool water and distilled water and mix together and then run the pH test in the normal way with that sample.
OK, so, you have very little CYA so chlorine about 2 should be ok. pH between 7 and 8 is OK. Enjoy your pool. Keep chlorine in there with bleach until the trichlor has supplied enough CYA to keep chlorine in the pool.
Thank you both so much. Ready to jump in! It is crystal clear and the temp is 101 so I'm in there!
Got my k-2006 today. Wow! This is what I've got:
TA-200 ppm
FC- .2
CC- no CC
ph- 7.8
Calcium Hardness- 600ppm
CYA- 30ppm ( or below, full vial never got cloudy)
Water still looks clear though I haven't added anything in 2 days (waiting on k-2006 to arrive)
How do I correct some of those awful test results and maintain?
1. Add a dose of bleach ASAP to avoid problems.
2. You have low chlorine and no CYA; use dichlor to chlorinate.
3. You can use the SSR => http://pool9.net/ssr/
4. But your water is at risk for scale or sudden formation of a milky calcium precipate, so . . .
5. Read the muriatic acid page => http://pool9.net/ma/, get some acid, and lower your pH to near 7.0 . . . and then KEEP it there.
A dose as in 1 1/2 cups? Doesn't seem like enough but okay. And I'm off to Sam's to get the Poolbrand Shock with stabilizer (which I thought I was getting when I bought the chlorine tabs but not the same thing) I've got Muriatic acid and have read the instructions so will give it a dose of that in the morning, too. Thanks, I'll get on it.
The SSR doses are sized based on your pool volume. If your pool is the 20' x 4' round you mentioned above, you have about 8,000 gallons
( 10^2 x 3.14 x 3.4' (water depth) x 7.46 gal/cft = 7,964 gal)
When I used "dose" above, I was being careless, and not referring to the SSR directly. Under your current circumstances, an appropriate "dose" is 4 SSR dosesfor your pool, or 6 cups of bleach.
No problem. Still doesn't seem enough for 8,000 gallons but you're the Doc. I have those 99.9% chlorine 3" tablets that I put in a week ago and they are not dissolving very fast at all, possibly because of the high calcium content of the water. I will dose and retest in the AM. Thank you so much.
Don't think calcium has anything to do with the dissolution rate of trichlor tabs.
Do you have them in a floater? Did you open the screen on the floater all the way?
Yes, 3 tabs in the floater...screen opened all the way....still barely dissolved after week.
