Maybe from the pool store but not from here. I have just reread the entire thread and you have been told several times:Quote:
Originally Posted by no1ford
1 to get a test kit, not strips, and test your own water
2 get your chlorine levels up to shock level and KEEP THEM THERE by adding BLEACH seveal times a day for as long as it takes to clear the water
3 keep your filter running 24/7
4 to read the info on www.poolsolutons.com
You were never told by us to add copper but you did. The pool store also told you to use flocculant. He is trying to sell chemicals to you, we are not. These additions have actually slowed your progress.
I truely believe that if you had followed the advice we have given you your pool would be clear and you would be swimming right now. It is not too late but it is really up to you.
Sorry if I seem to be coming down hard on you but if you don't want to follow the very good advice that has been given here then it really won't do much good.
And I happen to work in a pool store and I am the first to disagree with a lot of the 'pool store advice' that I hear! I will be the first to admit that at work I sell alkalinity increaser and not baking soda and that I sell liquid chlorine and not bleach but the store does need to stay in business. None the less I still tell people to attack algae first with chlorine before resorting to other algecides, to keep tabs on their stabilizer levels when they use stablized chlorine and be ready to either drain and refill or switch to non stabilized chlorine when the levels get too high, and I stress that good pool maintenece begings and ends with the owner taking responsiblity for their pool and doing some testing at home in between complete water tests at the store, at least testing for FC and pH and not with strips! Unfortunatly, I have found that many people just want a 'magic bottle of stuff' to pour into their pool and fix the problems. There is no such thing!
I try to educate my customers about proper pool care and it pays off in repeat business! However, there are some that just don't want to hear it no matter how much I try so I just sell them a bottle of this and a bottle of that knowing full well that it won't fix their pool becuase that is all they want. You have to decide which group you want to be in.
I learned much, if not most, of what I know about pool maintenence right in this forum and it works!
Try it for yourself and see!
