Do not put the polymeric sand in the joint between the deck and the pool coping. Even with pavers you need some expansion. It is best to install elastomeric caulk and sand the top. Pick a caulk color that will best match your polymeric sand color. Do not use play sand to sand the elastomeric (Ive seen some joints come out looking pink with the play sand)
Hope this helps
