Re: Need a special tool!
Only thing I can think of is using a long bar to push the wrench jaw against the raised square on the plug so it will grab as you turn.
I find when I use a basin wrench to loosen a tight nut on a faucet that I often have to squeeze it as I turn. The spring doesn't always apply enough pressure for a good grip.
The grip seems very strong. In fact it is strong enough that I am able to turn the socket on the end of the wrench without loosing grip on the plug. Pool guys is coming back with a "T" wrench today so lets see if that works.
Thanks for your help
John
:) :) Pool guy got it with the T-wrench, I have a waterfall now! :) :)
Thank you everyone for the help
John
