Read about it here http://www.focuspools.com/store/prod...?product=NCI48
I have no idea if that's a good price or not. I just wanted to show you some info on dosage and usage.
You can also use a metal sequesterant (like Jack's Magic) and lower your PH - sometimes that will lift a stain without the absorbic acid - but some experts (like mbar) can help you better.
Also - you want to get your fill water tested for copper and iron and probably keep some sequesterant in the water to prevent this in the future. Good luck!
Doggie,
Thanks for the site info. I cruised around on the web a bit and couldn't find another source for the StainFree and the Metal Free was cheaper on your site than a couple of others I checked.
Simmons99,
Where can I find equipment for testing for metals or do I need to do that since my Vitamin C test was "positive"?
Must I take the water sample to my (gulp) local pool store to have it done?
Thankx.
CoffeeBean
Also, as I read and read other posts....
Smallpooldad posted back in June `06 that it's necessary to drain the pool after using AA and a metal sequesterant. Ummm...I don't think I can do that. It costs well over $500.00 for a tanker of water and that doesn't fill the pool.
Also I read somewhere that the water temp has to be low. Mine's at a steady 82 F because I've had the heater on.
I'm getting more confused and more reluctant to do anything for fear I screw things up royally.
Advice please?
CoffeeBean
I haven't read anything about lowering the temp. And if you drain the water, you might end up right back where you started if there's metal in the fill water. Just be sure your chlorine level is low while you do all this. Otherwise your water will get very cloudy.
Don't worry, things will be fine. :)
No, you don't have to drain the pool! Small pool dad did a different stain treatment. I will print the ascorbic acid treatment - ascorbic acid is vitamin C. The fact that the vitamin C took the stain off makes me believe that the stain is from metals. The stuff you were able to take off with a sponge was either algae, or metals that fell out of solution into more of a solid that was able to be washed off. You may have algae, because you need a minimum of 8ppms of chlorine in your pool at all times when you have a cya of 100 in order to have a really sanitized pool. Here is a copy of the best guess chart:
Ben's 'best guess' FC/Stabilizer table for algae free operation of OUTDOOR pools -- as of July 2003 --
Use the info in this chart to help you figure out what levels of chlorine you need to maintain in your pool based on the amount of CYA (cyanuric acid, also called stabilizer) that you have in your pool. (FC = free chlorine)
Stabilizer . . . . . . Min. FC . . . . Max FC . . . 'Shock' FC
=> 0 ppm . . . . . . . 1 ppm . . . . . 3 ppm . . . . 10 ppm
=> 10 - 20 ppm . . . . 2 ppm . . . . . 5 ppm . . . . 12 ppm
=> 30 - 50 ppm . . . . 3 ppm . . . . . 6 ppm . . . . 15 ppm
=> 60 - 90 ppm . . . . 5 ppm . . . . . 10 ppm . . .. 20 ppm
=> 100 - 200 ppm . . . 8 ppm . . . . . 15 ppm . . .. 25 ppm
Here are two links you can get ascorbic acid. The link from the "chemistry store" gets you the ascorbic acid faster, but the other link lets you get a smaller amount.:
http://www.chemistrystore.com/Ascorbic_Acid.htm
http://www.msm-msm.com/store/agora.c...scorbic%20Acid
Here is the ascorbic acid treatment:
Here is the ascorbic treatment:
You will need about a half to one pound of ascorbic acid per 10,000 gal. I like to go lighter on it and see if all the
Put the filter on circulate.
Use a cup and go around the perimeter of the pool and drop it down the sides as you go.
Let the ascorbic acid circulate for 1/2 hour. You will be amazed how the stain just disappears before your eyes.
If the stain is not all gone, leave the filter in circulate and add more ascorbic acid close to where you still see stain. Leave it in circulate until all of the stain is gone. (add more ascorbic acid if it circulates for 1/2 hour and there is still stain)
When the stain is gone, add enough sequestering agent for the volume of your pool - more is better than not enough.
Put the filter back on filter and leave it on 24/7.
The ascorbic acid will bring your ph down, after 24 hours you can start to bring up your ph and alkalinity - use baking soda first, it will raise both ph and alk. Make sure you test in between, because you don't wantyour ph to go any higher than 7.2. If your alkalinity is in range, and you still need to raise your ph, use Borax to take it up to no higher than 7.2. After 48 hours you can start to bring up your chlorine. You want to do this slowly. It will take a lot of chlorine - I prefer to use bleach only at this time, and try to take it up to your minimum chlorine for your cya according to the "best guess chart" Do not shock! Do not shock for at least 2 weeks! Make sure you keep your ph low for (7.2) for a week or two - it won't be hard because the ascorbic acid will help it stay low. Once your chlorine starts to hold, it means that you have used up the ascorbic acid in the water and it will be easy to rebalance the pool back to your regular parameters.
If you plan to close your pool soon, I would suggest you wait till the spring to do the stain treatment. I have already closed with stains and opened to a stain free pool, so you may just want to enjoy your pool till you close and deal with it next year when you open.
If you have any other questions feel free to ask:)
Thank you so much mbar & everyone for your help!
Just a couple more questions:
Where/how do I get the water tested for metals?
mbar, you said:
"You may have algae, because you need a minimum of 8ppms of chlorine in your pool at all times when you have a cya of 100 in order to have a really sanitized pool."
My CYA is 30. It's been ranging form 20 to 30 all summer. Did you think mine was 100?
Unfortunately, when I ordered more CYA from Ben earlier in the summer I thought I was getting two 4oz bottles but got two 2 oz bottles instead. Now I'm out and can't test it anymore. It took nearly 4 weeks to get the last order. Is there any other really quick source for CYA reagent? Our local pool stores just looked at me strangely when I asked if they carried it.
Mbar, you mentioned waiting until spring to clean up the stains. So it won't hurt it any if I close with the stains on the walls?
Thanks again for your continuing support and help. By the time I get this all figured out my kids will have kids of their own! (They're 11, 15 & 16 now)
CoffeeBean
Oops! I read the cya as the alkalinity, down from 120 to 100:eek: Sorry. Yes, you can wait till next year to clean up the stains - they will come off then, and maybe they will go away over the winter. You can get your water tested at some pool stores, or you can sometimes get it tested by your city. Where does your water come from? If it is from a well, then you will need to get it tested on your own, if it is city water they should be able to tell you what is in it. You won't need anymore cya regent until next spring. If your cya has been running around 30, then you are at the low end of cya and even if you are using trichlor pucks you probably didn't come up much. If I were you, I would close the pool this year, and before you open next year get some ascorbic acid, sequesterer, and new regents so you will be ready to go. You can do the stain treatment before you get your whole pool balanced, this way you will only have to do it once. As soon as it opens, take care of the algae (if the water is green) first. Then check to see if there is stains - I have opened to a stainfree pool every year, even if I had some at the end of the summer before. If you do have stains, do the stain treatment with sequesterer. Then balance the water, then have a wonderful summer:)
Thank you so much, mbar and all the others who have responded to my plight. I feel much more confident about dealing with the stains - next spring. That takes such a load off of my mind.
Gratefully,
CoffeeBean
Ahhh, the mellow, friendly vibe of the PoolForum. So nice to be back. Course, I wouldn't be here reading if there wasn't just the teensiest little problem of my own. Hmmmm.... Vitamin C tablets, eh? Wouldn't hurt to have a little stash of those around the house anyway, and they're certainly not very expensive. :)
