The new motor is 115 volts and 12 amps. So I shouldn't have to change the breaker, right?
The breaker may be weak so it may still need to be changed but I would look elsewhere for a problem.
FYI, you should also check that the wire into the breaker is tight. A loose wire will cause heat build up and increased resistance. You should periodically check all the breaker screws to make sure they're snug - but don't do this with any power on at the breaker.
You should not simply replace a 15 amp breaker with a 20 amp, unless the wire size is 12. I cant imagine someone using 14 gage wire (15 amp) for a pool but you should check before replacing the breaker.
Thanks for the advice everyone. I purchased a 15 amp 115 volt extension cord and it's working great. Now I need a fixed outlet.
Thanks!
Another stupid question. The pump doesn't seem to have an on/off switch. Do I need an electrician to wire one?
Thanks!!
you'll want to get a outdoor timer for your pump and it will have an on off switch on it.
This is just a sample i have never bought anything from these people. http://www.intheswim.com/Pool-Filter...e-Ground-Timer
