As a former plumber (sort of) I will say that the recommended times around with teflon tape that I have heard of is 6.
thanks guys..i think i've basically got it..managed to get the pipe to grab and put about 4 turned around..one still leaked just a touch..but it was so little i was able to put a smear of silicon on it and it isn't leaking anymore..came back from my vacation and no leaks (it was running 12 hours a day so a good test)
If pipe wrench is not working, you may have to upset the misses and grab her jar opener pad. Place it in between the pipe and the pipe-wrench or channel locks. I have used that technique over and over. Should get you tight enough to stop any leaks. Good luck.
Use teflon sealant paste, not tape. I just installed a heater also and I found the tape was causing a little leak where it connected to the copper pipe.
