Newpoo, that's funny-Neil Armstrong. I was wearing shorts when I poured the acid in-maybe it'll be long pants from now on. Denise:)
I always pour the acid into a old glass canning jar. They have measurements on the side of them and are easy to handle.
I had posted the same question about a month ago....I was loosing my shorts and shirts from splashed acid that I didnt notice.
The recommendation was to dilute it in a bucket first then toss the bucket in the deep end.
Since then, no new holes in my shirts! I dilute roughly 5/1 water/acid
I pour it out of the jug slowly at the waterline in front of a return. I wear gloves, goggles, and a respirator (indoor pool).
Couldn't you substitute granular Sodium Bisulfate to low PH? Is there a benefit to the Acid that the Sodium Bisulfate wont provide?
I believe muriatic acid is cheaper and doesn't add sulfates to your pool. I was given certain chemicals when we purchased our pool and sodium bisulfate was one of them. I used 2 3lb containers in the pool and it only brought down the ph by 2 points. When I first used the muriatic acid, I poured approx. 3/4 c into the pool and it came down by 2 points. I still have a lot left in the gallon jug as compared to no more dry acid. Hope this helps. Denise
If you have a SWCG, then Muriatic Acid is the only pH reducer you should be using. As Mohawk says, sodium bisulfate only increases you total TDS.
Pat
I'll be adding my first dose of Muriatic Acid tonight (pool just filled this past Saturday). I like the idea of measuring how much to add with a glass measuring cup. Do I rinse the cup after I pour the acid in? I would think not given the "never add water to acid" warning. Do I just leave the cup to dry?
I use a plastic measuring cup, and when I've poured all the acid in, I dip it in the pool and pour it out 4 times, making sure to get it totally rinsed, then set it aside to air dry in the garage with my other pool tools.
Yeah, just quickly dip the measuring cup into the pool water and empty a few times. No violent reactions here so far. :p
