Re: brown stains along rim of pool, vitamin c does not remove stain, idea?
Keep us posted of the results if you try the Metal Magic!
I loaded 3 tabs into a sock and it did indeed remove a lot of the stain. So the recommendation is superchlorination to 30ppm? How long do I need to maintain that level? Also, is this likely to cause me to need to backwash? I just put a couple of pounds of cya in and I want to avoid backwashing...
It shouldn't cause you to have to backwash.
I ordered Metal Magic today. I am hoping that it is MAGIC! I must have tons of iron in my water. My stains are starting to creep back and I have tons of sequestering agent in the water, Ph at 7.2 and 3ppm Cl.
