Do you think you have water coming from the backwash discharge pipe when the pump is running? You may need a new gasket in the multiport valve if that is the case. That would explain why the you are losing alot more water when the pump was running. I'm sure somebody with more experiance will chime in I'm a newbie myself. Good Luck.
Jennifer
