Re: New pool cloudy water???
What is your pool store using to test the PH? Either you or the pool store is doing something incorrectly to get such different results.
If the pool store is using strips it will be inaccurate.
Did you let your wife test the water at home with the test - maybe you are doing something wrong when you are testing?
The pool store is using strips and I am using a 6 way test kit. The pool cleared up until I hooked up the heater (was given to me) and cleared the pipes on heater so it should clear back up today.
