The reason linear quats foam is they are cationic surfactants. This is a class of synthetic detergents. Nature of the beast. Best advice is to not use them. They also can cause eye stinging. If you must use an algaecide use polyquat.
I have used them before though, without foaming problems, so I was wondering what conditions promote foaming. Is it usually due to overdosing, do ph, chlorine, hard water etc. have a big effect?
Also does chloring quickly destroy the quats and their effectiveness?
HTH has changed their algaecide 60 -- it's NOT polyquat anymore. I use Pooltrine from Leslies online for $7.73/qt. Last time I checked it was $9 something a quart - still cheap. You have to purchase it online, though - their stores do not stock it. Only downside is no measuring guide on the bottle, you have to measure it out into a measuring cup, but small sacrifice for a huge savings! I use a maintenance dose once a week just as a precaution- my water is gorgeous and glistens!!
My current view of HTH is that if you cannot find the WalMart 5 way test kit, they sell no other product I know of that I can recommend. They don't even seem to sell the 68% cal-hypo anymore, though I believe their sister company, also owned by Arch Chem, does. But I don't remember the name.
Carl, Arch owns the HTH brand. HTH is, and has been for years, just a trademark.
Olin spun off the pool chlorine operation several years ago, including the Charleston TN production plant (about 6o miles up the road from me!), to the Arch company. I'm not clear on whether Arch is an entirely independent company, or is owned by Olin. But it is independent.
The 5-way kit, as you know, is a Taylor kit relabeled for Arch / HTH.
The plain calcium hypochlorite product made by Arch is still fine.
But, Arch is now run by a former BioLab VP, and is blending and selling all of the chemical messes (4n1 shock, etc.) that are BioLab's hallmark.
However, some good things may be in the works for Walmart. This year, at least in Chattanooga, Sams Club has been selling plain, basic pool chemicals for very low prices. They are labeled by some company I've never heard of in New Jersey. My guess is that they are an importer for Asian companies that can actually make money selling commodity chemicals. Anyhow, they had prices for plain dichlor and trichlor that were substantially below common wholesale prices! I'm hoping that this may respresent a trend, and that all Walmart stores will begin selling basic pool chemicals, instead of the Arch / BioLab blended messes.
Ben
PoolDoc
Ben,
Does it matter if HTH is simply a label or a wholly owned company of Arch's as long as ALL policy decisions regarding HTH are made in Arch HQ? I suppose there's a technical difference but the ex-biogard CEO is calling ALL the shots either way--and I think both you and I agree that we don't like those shots he's calling.
But I thought they (Arch) had another label/brand/company that is still shipping 68% cal-hypo--PoolClear or something--I don't remember.
Hey Carl,
I think Poolife is the company you're thinking of. I got some of their active cleaning caplets that are still 68%. Here's an online link to it:
http://www.hydropool.com/cgi-bin/hyd...ng_caplets.htm
Peter
Before showing my father this site, he had bought some linear quat algaecide of the HTH & PoolBrand variety. Since he can't bring them to the Philippines and is a new convert of the BBB method (plus some judicious use of polyquat), he has dumped said algaecide on me. Besides the possible foaming, what other side effects are associated with these products? Are they effective at all or should I just pour them down the drain? I believe it was noted that ammonium chlorides do kill algae, but with the side effect of reducing FC and increasing CC.
I don't know about the side effects
but if you really want to use that stuff instead of dumping it down the drain:
you could use it during your pool closing ( who cares if you get foam then?)
you could run around to all the bird baths in town & use a eye-dropper full
you could sell it at a fleamarket or yard sale
you could give it away
you could mix it with water & spray your house roof or shed roof
( to get rid of growths from tree debris)
My neighbor had foam so thick it wouldn't even flow into the skimmer.
We made up a couple of gallons of dish detergent and water mix in a pump sprayer and dissolved it. The pool was such a mess at that point I figured it couldn't hurt.
