Hi Grace;
I was just concerned that you might neutralize to early. I'm glad you are ok.
Jo
Hi Grace;
Jo
So what are your numbers tonight?
Tundra thanks for asking. My numbers as of 8 p.m. tonight are as follows:
FC 3.0
TC 3.0
Ph 7.2
Alk 120
Calc 350
CYA 50
this morning when I woke up I ran the numbers and came up with a higher chlorine and a zero CYA. I was confused after having added stabilizer per CarlDs instructions the night before. In researching on the forum I found a post from the 12th of June referring to a problem with the CH test and my Walmart kit specifically. Waterbear suggested a way around it and when I followed those instructions tonight, lo and behold I got a Calc reading of 350.
I think I'm ok, right?
If your water is clear, you look pretty good. But with a CYA of 50, I suggest you maintain FC at the high end of the 3-6 ppm scale. If the CYA range is 30-50 and the FC matching range is 3-6, you probably want to match your CYA to the same side of the range.
But otherwise your numbers look good.
I'm concerned that you say you had zero CYA this morning...yest 50 tonight?
I was concerned too. But in researching what could possibly be causing that result (ie tester error :o ) I came across a post from 6/12 on another part of the forum which was relevant. It seems the particular kit I'm using from Walmart, seems to have a problem with the hardness test. Waterbear posted an alternative way to conduct the test using the kit, sorry I'm not too well versed to explain the why of it. When I conducted that part of it following those instructions it came up 50.
I printed out those instructions so that I could conduct it again this morning to compare. I'm sure that it is a more realistic result, consistent with previous numbers.
yes, but CYA is not a hardness test...i'm not concerned with your cal hardness numbers...i am concerned (test kit error) with your cya stabalizer level numbers...it really can't be 50 and 0 in the same day...or did I missread something?Quote:
Originally Posted by Gracy101
BIG OOOPS! Didn't mean CYA of 0 I meant a calc or hardness reading of 0. The post I was using as reference referred to the hardness test. I mistyped the abbreviation in my post.
Good catch Tundra and thank you for having my back. I need to get a little used to all these names/abbreviations. :o
