Re: My turn to ask questions
Three days over 12 ppm, three nights over 15; and we can make out the pattern on the bottom of the deep end and the main drain is now visible. My Dad can see it with his good eye and is beginning to believe in the system, in spite of what it "cost". Thanks very much Dave S. for your help thus far. I am hoping to get the ph out of minimum range next.
So... the pool is clear and at 4:30 the readings were:
Cl 10-12 let's say 11 using 3:1 and 4:1 after a full day of sun,
(will bring it back to 15 later tonight with 9qts, right?)
pH 6.8 (a whole box,ok?
TA 50 (9lbs baking soda? and see what I get tomorrow?)
CYA 30 (just glad I can measure it!, should I adjust?)
The only thing greater than your patience has been your advice (or the other way round? Let me know if I'm on the right track...
Karen Lee
Hang in there, and keep shocking--the good news is that once you get it cleared up, it's MUCH simpler and a lot less work to keep it up! Go ahead and add a box of Borax to your skimmer--you don't have to wait until tonight. I would start with about 4 boxes of baking soda and then retest tomorrow before adding the rest. Leave the CYA alone, it's fine for now.
Hi, Karen,
Nothing to add to Janet's post other than to chime in my encouragement. I think you're doing well. Keep us posted:)
I just came back from testing and
Cl= 12
ph= 7.2
TA= 100 (yesterday)
CYA= 30 (yesterday)
I have thing where I think they should be- pool looks clear needs, to be vacuumed but I didn't because my dad's SO is having a get together with her friends today, (she wouldn't lift a finger to help get it ready), just wants to lie on a float for hours talking.
I will start to let chlorine lessen tomorrow and try to keep it where, between 3 and 5? I think the rest is tracking good so far.
Just a quick note of encouragement for you:-)
Clearing up water problems is all consuming and expensive - I know! I spent two summers as an undereducated pool owner, trying to clear up algae and then the calcium precipitate that resulted from the way I used the pool store chemicals. (It wasn't the pool store's fault; I misunderstood how long to go between doses and messed it up myself).
But keeping the water clear using the information from this website is really cheap and takes 5 minutes a day, plus standard maintenance of vacuuming about once a week and brushing 2-3 times a week. Ocassionally, you may fall behind or miss a few days of checking, and then you may have a small water problem to clear up. But its not a big deal to get it back again.
Eventually, the pool will be a wonderful family blessing, the place where everyone wants to be, great exercise, and just plain fun. Don't give up!
