Re: What are the Perfect Numbers?
Originally Posted by CarlD
It was '42' I thought.
I think you're right...been years since I read it...they say the memory is the second thing to go:eek:
When I was a kid, perfect numbers were 36-24-36...:D
They still are!
Actually Waste goofed on CC:
Sure, .05ppm is OK, but you can't read that. Usually, you can only see that it's .5 ppm or less. If you use the 25ml line, you can measure CC down to .2ppm
Once again Carl is right!
Jeeze Carl, I was quoting you almost verbatum, you gotta go and complain about a simple order of magnitude?? :p
