The *RIGHT* way to start up, or cure, plaster pools . . .
. . . is something I wish I knew, but I don't.:rolleyes:
There are multiple methods, all of which have (as best I can tell) 'worked' some of the time, and all of which seem also to have 'failed' some of the time.
This is an area of huge dispute in the pool industry, with some confusing research of varying quality being brought into play. Everybody who's studying this -- and plaster is one of the few areas of pool construction and operation that is being seriously studied in public -- has an axe to grind, and knows what they really, REALLY WANT to find. Some of them are still trustworthy, I think, but it makes it tough to fit all the bits of research together.
The bottom line?
I do NOT know the best way to start up plaster pools. There are plenty of people who are entirely sure that THEY do know, but the evidence is too confusing, and to contradictory to warrant any such confidence. As is said of other disputes, this is one where's there more heat than light!:mad:
There are a few things that seem to be held by all, or at least held by some and rejected by none:
When starting or 'curing' a newly plastered pool . . .
+ Brush a lot, and don't let stuff build up.
+ Avoid high alkalinity (> 160 ppm)
+ Avoid metals, even if you plan to use a ionizer later.
+ Avoid adding lots of salt, even if you plan to use a salt chlorinator later.
Beyond that, you probably had best go with what your contractor requires of you, in order to maintain your warranty on his work.
One suggestion that I'd make is that you get -- demand, if necessary -- all the conditions he expects, in order to maintain your warranty. Then, make a log sheet and DOCUMENT your compliance with his requirements. This won't prevent all problems, but it should help prevent, or at least minimize, some of the many disputes over whether the problem was caused by the pool owners failure to maintain pool chemistry.
Ben
