Bromine is less pH dependant and will work fine in pH as high as 8.0 but I would still keep it in the 7.4-7.8 range for comfort of the bathers.Quote:
Originally Posted by DaveD
Ozone will work with bromine and against chlorine. Ozone will convert the bromide ions in the water from your bromine reserve (you need to add sodium bromide on each refill when using bromine, even with the tabs in a floater!) into hypobromous acid. it will keep your bromine levels more constant and you might need to shock less. Ozone will lower chlorine levels and chlorine destroys ozone so the two tend to work against each other. Even with ozone I would run my bromine about 6-8 ppm or my chlorine about 4-6 ppm so there is enough residual sanitizer in the water to keep it sanitized while being used...remember the ozone will only kill bacteria that come in contact with it and there is no residual in the water you are soaking in!
