The problem is that as your stabilzier levels increase you need to increase your FC levels to keep enough 'active' chlorine in the pool. You then use more pucks which then increase your stabilzier levels even more.
Check out this thread for info on chlorine levels and stabilzier
http://www.poolforum.com/pf2/showthread.php?t=365
