Depends on what you need. If you are trying to skim floating things off the water surface, then upwards as you described. But, if you are adding chemicals, I think it is better to aim it more downward.
There's no standard answer to that question. From what little I've played with it, slow circulation is best. If you get a whirlpool going, stuff moves to fast for the skimmer to catch it.
I think we have the pool in good shape now. I think the floating stuff is airborne and landing in the pool. Thanks for your help :)
Really?
Cottonwood?
Your IP address says you're around Phillie. Is that right?
Cottonwood (Populus deltoides) is pretty uncommon there, as it is here. But it will grow, and I've located a couple of stands. Good grief those seeds go EVERYWHERE.
I'm about 40 miles from Philly. I don't know what the stuff if. I'll try to get a picture.
If it's cottonwood fibers, you should be able to net it with a fine kitchen strainer.
Most likely pollon. Disappeared after we swam today.
Darn. Mystery un-solved! :(
