My pool is doing wonderfully!! Thanks for all of your help, plus the Taylor. We are on target! Don't forget me though because I may have more questions! :)
We'll be here! ;)
3 parts combined chlorine
PH 7.8
akalinity 90
is this a good place to be in the early morning at the beginning of a very sunny day?
Not the 3ppm of CC! Ideally, you want that to be 0. Try the chlorine tests again. These testing video demos might be helpful.
http://pool9.net/K2006-vid/
Your pH and alk are fine.
When you re-do the tests and re-post, please list FC and CC readings.
what about 0.3 combined chlorine??? Ugh!
PH 7.8
akalinity 90
0.3 CC is acceptable although I'm not sure how you got that reading. If you use a 10mL water sample, your readings are always in increments of 0.5 and if you use a 25mL sample, in increments of 0.2.
(A CC reading of 0.5 or less is ok. If it goes over 0.5, then you'll want to take your chlorine up to your shock level.)
