Re: New Guy, New Pool, Already been Pool-Stored... Always happy to learn
Thanks Watermom for the insight... I was over looking at the BBB method from TroubleFreePool.com Looks like they recommend the same. I will be getting the HTH 6 way tester, as I need to go to Walmart anyway for the Borax, Bleach and, Baking Soda.
Skeet Shooter
I think I will start doing this tomorrow, since I will have my kit by then, and I'll start raising the chlorine levels... right now
I hope you ordered a K2006 -- as far as we know, you can not get one locally. You CAN get a cheap OTO / phenol red kit, and those are worth having, even if you have a K2006.
The 6-way kit can only test chlorine levels up to 5ppm. If you can, you are better off getting a Taylor K2006.
Ah I did not know that... So i guess I will have to Order the Taylor then. Sucks that its 3x the price though...
Yeah but definitely worth it. You won't regret it. ;)
Hi just got my test kit:
pH was less than 7
FC: 1.4PPM
CC: 0
Calcium Hardness: 70ppm
Alkalinity: 40ppm
So I'm currently adding 1 gallon of 8.1% Liquid Bleach to the skimmer every hour till chlorine reaches 5ppm right? As far as PH, that should come up as well, however should i also add Borax as well or should I wait.
Thanks,
Jason
1. Add borax, a box at a time, till your pH is above 7.0. Allow 1 at least hour of pump ON time, before retesting pH. Add it slowly, to the skimmer, with the pump running.
2. For now, add 1 gallon dose of bleach each evening, directly to the skimmer, but NOT on top of any tabs. (Make sure bleach and tabs NEVER touch!)
3. What is your stabilizer level? If your CYA (stabilizer) is low, chlorine will NOT last through out a day of full sun, no matter how much you add. Instead, if you have swimmers during the day and have low CYA, pour 1/8 to 1/4 gallon doses into the skimmer periodically. This is in ADDITION to your evening gallon. I'd recommend getting a cheap OTO/phenol red kit, for quick testing during the day: add chlorine if you have swimmers and the OTO results aren't medium yellow or darker; skip doses of chlorine test result IS dark yellow.
OK great... So here are my newest test results.
PH is now around 7.4 based on my observations and tests.
I added 2 gallons of bleach, which brought my Chlorine levels up to 15ppm (totally should have waited i know)
my CYA level is too low to register anything on the test. Should I buy Cynuric Acid? Or should I just get TriChlor? Or both?
Either way works. I typically just buy it separately.
Alright so finally I am in the Ballpark! WOOHOO! Here are my numbers after adding a little more than 4lbs of Stabilizer:
Ph: 7 (Still too low, I'm going to add another box of Borax tonight)
FC: 7.5ppm (Yes still a little high, but thats OK... I will try to maintain a 6ppm based on the Best Guess Chlorine guide.
CC: 0
CYA: 50ppm
Water is perfectly clear, albeit cold at 70*.
Thanks for the help all. I do believe I will need to purchase another filter, because changing a filter takes a while to clean it properly and then cap and uncap the filter. (I currently do not have a shut off valve plumbed in between the inlet to the filter, and for some reason my shut off on the outgoing does not seem to work. When I drain off some of the pool water, I will probably just put new valves in.
