Re: Replacing cartridge with sand
Earlier you said that the "pool isn't all that clean" is the reason you are considering filter change. I thought that meant water quality (to me: little tiny stuff in water that makes it look dull). Did you mean something else by clean?
No thanks needed (but appreciated), I like to help.
BigDave
And, Dave, we appreciate all the help you do give! Thanks!
what I meant was sometimes the filters seem like they don't do enough to keep the pool free from debris. The sweep works fine. Thanks, Dave
You could either have inferior brand cartridges, you are not cleaning them correctly, or your cart is too small for your pump.
A properly sized cartridge filter, properly maintained, should perform better than a sand filter but not as well as a DE filter.
Most people here don't like them because they are tricking to clean, but those who figure out how to clean them well, and with little effort, swear by them.
I have decent cartridges but I need to find a better way to clean them. I saw a device where you lay the filter down in a tray and run the spray nozzle over them, plus I may need to get rid of a couple. How long are they supposed to last if cleaned twice a year? Thanks to all Dave
dansdad
Twice a year? I clean my cartridge weekly during the summer and fall. Twice a week in the spring. Once a month (roughly) in the winter.
I've never had a cartridge get ruined but after about a year the "clean" filter pressure ends up about 10psi higher than the "clean" pressure was when I bought it. I replace mine roughly every 18-24 months.
just as you mentioned it, I looked and ordered cleaner for the cartridges. Will be ready for summer. Thanks Dave
kelemvor
Your cartridge filter is obviously way too small for your pool. A properly sized cartridge system should only need to be cleaned once per year. Also, frequent cleaning is probably the reason you are replacing them so often. I have had my cartridges for 8+ years, clean them only once per year and the filter pressure never gets more than 1 PSI above the clean filter pressure.
I am also one of those people who would never trade a cartridge for any other filter type. I just think cleaning it once a year is far easier than backwashing many times per year (my parents had a sand filter).
