Take a look at mwsmith's bleach calculator at http://www.hal-pc.org/~mwsmith2/BleachCalc262.exe
It will help you figure out how much bleach to add based on your pool gallonage.
There are recipes on the Nature 2 website for the low-chlorine system recommended when using Nature 2. I've been doing it and it works great. So does the Bleach Calculator that was already mentioned.Quote:
Originally Posted by sevver
There's a lot of opinion on this forum re the Nature 2 system, nearly all of it negative. Take it for what it's worth and make up your own mind.
Very handy, thanks, it appears that there are other conversions possible as well.Quote:
Originally Posted by aylad
Yup. I just do the arithmetic and I cannot see how the initial cost plus the $90 or more per season for N2 cartridges are not more costly than just using sufficient bleach. $90 buys a LOT of bleach each season. Even at $1.50/gallon of regular bleach, that's 60 gallons worth. I won't use that much in a summer, so where's the savings?Quote:
Originally Posted by nickapo
