before
https://lh6.googleusercontent.com/-V...0629121656.jpg. . . afterhttps://lh6.googleusercontent.com/-G...0702121603.jpg
http://i437.photobucket.com.KILLED/a...0629121656.jpg
http://i437.photobucket.com.KILLED/a...0702121603.jpg
Looks good, but BRUSH the pool, while the chlorine is high. You may stir up hidden piles of algae, that will turn the pool green again, if the chlorine is not high.
Then filter, filter, filter. Using polyquat, once the chlorine drops into the normal zone (per Best Guess chart) will simultaneously help protect against a recurrence and help filter out the dead algae. However, there's no need to keep using it, once the pool's all cleaned up.
thanks for all the help, she cleared right up, Should of found this site a couple of hundred dollars ago.
thanks Kevin
Glad you got it cleared up!
