Re: PS234 Kit Salt Option/No Instructions
Thanks Ben... I've sent you the e-mail.
Thanks MLH for the instructions.
Just another data point on the Salt Test.
I've started from scratch and as a starting point to get me close but under the the 3200ppm target, added 600 lbs of salt to the pool. Filter has run 30 Hrs straight and my aquarite readings leveled out at 2800 ppm as expected. Using the instructions above, I performed the salt test 3 times tonight. I used 30, 31, & 31 drops for adjusted readings of 6000, 6200, & 6200 ppm.
Pat.
