Ok. The plastic solar mats would work well for you. AND, any kind of cover that prevented evaporative heat loss would be a big difference, as well.
Thanks PoolDoc. The solar panel is working well. I couldn't be more pleased with how my pool turned out. Thanks Pool Forum!
Wanted to give an update!
My pool has been fantastic!! Water temp. is about 85*, clear, and sparkling.
Here are my test results from the K-2006 kit:
pH = 7.2 I haven't had to add borax or muriatic acid
FC has been holding at 6-8.5 ppm
CC = 0
CYA = 55-60
To maintain FC I've been running the SWCG for 1 to 3 hours per day depending on use. I did NOT connect the copper ionizer.
This has been super simple and easy thanks to this forum and all of you! Thanks pool forum!!
"Super simple and easy" also thanks to your planning and research - kudos to you!
