Do you friends in the U.S. to visit? Perhaps you could have them order a K-2006C for you; It won't be easy (probably impossible) to find in stores. I suggest the C version because the reagents supplied are 2oz instead of 0.75oz.
If you do decide to use an algaecide, make sure is it Polyquat 60%. Most cheap algaecides causes foamy water.
The Taylor K-2006 kit is only available online. So to get it, you'll have to order it and send it somewhere in the US and then pick it up on your trip here. While you're at it, I think I'd go ahead and order some extra CYA testing reagent R-0013 so you'll have some for if you run out, especially if you are going to use Trichlor tabs. (The kit only has enough for a handful of tests.) The R-0013 is listed on the test kit page.
