PoolDoc
No. If you have 0.0 ppm copper, it's not an issue.
:D You're not 'using' the Frog, your 'abusing' it!:p
The mineral reservoir has copper in it. But I don't think it always succeeds at adding copper to the pool (in other words: it fails to work, which is good, but expensive).
You're sort of working around their program, using their feeder. You need to watch out for staining when you replace the mineral pack. However, if you are just using the plastic cartridge as a holder for your own tabs . . . why do you need a new one?
