Yes, but don't do that. We don't know what your TA is, and it may be too high. Use borax.
The only reason i have not gone to crazy with everything is because there is a leak somewhere.
I been trying to find it but have not found it yet. I lose a a inch or so a day. I know the leak is in the liner. I been llsong water all winter. My pool is half in ground so no wet spots. Any tips? ?
Wow. Finding a small leak in a liner is hard.
On a pool your size (thanks for completing the chart!), a 1" leak per day is only about 120 gallons, or 5 gallons per hour. That's a fast drip.
There are 3 ways to find it that I know of:
1. Find it on the outside, where the water is coming through. Sounds like you've already checked all the exposed outside.
2. Let it leak till it stops; usually the leak will be within an inch of the water line. You could speed up the process by pump out 12", and seeing if it still leaks, then 12" more and see if it leaks. The leak will be in the LAST 12 band you check. Refill 6" and see if it leaks. etc.
3. Get in the pool with a mask and snorkel and look for pinholes or bad seams. If your pool walls are steel, you might feel for rusted steel under the liner, too.
The leak is at the bottom. Over the winter i looked a d watched the pool go.empty. but with snow i could nkt let it stay empty in fear of walls closeing in. From.weight of water snow or ice on cover.
Do you know WHERE it is? You can patch a liner; it's best dry, but you can do it underwater. However, you have to know WHERE to put the patch!
thats were i am stuck. I am not sure were the leak is. i only know its on the floor. I felt a one or two craters. But when i tried food coloring i go no were
Yeah, it's gonna be hard to find a leak that small. I'm sorry, but I have no ideas, except to drain and do an inch-by-inch inspection.
local pool store does leak detection. 150 patched no matter how many holes they find
I got the test kit you all suggested. However it is extremely confusing. I hae no idea how to use it lol
