Re: My water is a mess, I don't know where to start
+ Add borax till you get above 7.4
+ You can add stabilizer now, but it will slow the clean up process -- and you'll have to use higher levels of chlorine, which you can't test yet.
+ Yes, you can add bleach in the AM, if you don't mind the wastage. Doing so will speed things somewhat.
Okay, I will get the borax that I have left in there and if I need more tonight I will do that. I can do bleach in the a.m. as well to try and speed things along. I need to develop my P.O.P., right now it seems to be at about the level of a 7 year old. I want it done now! ;)
Do I close the cover during sunny hours to help save the chlorine or leave it off to let gasses escape and the sun help break some things down?
Still need an answer to the chlorine testing question, match color immediately or let it develop a little first, since it seems to continue to get darker with time?
10:15 retest of the pool (6 gallons of bleach added just over an hour ago)
CC about 1 ppm (read immediately after mixing the chemicals in testing water)
FC 1 ppm
pH 7.2
TA 280 ppm
I can see that the white slime on the top seems to be breaking up some. What is that gross tuff anyway?
12:15 test:
FC between .5 and 1 ppm
TC was out the roof
CC was .5-1 ppm
pH was 7.2
Almost all the white was gone, still looks like an oil slick on top. Might be a little clearer, but certainly not clear.
Right now, it's not worthwhile to try to discriminate between initial color and developed color. Just keep adding bleach, till you can hold chlorine overnight. Then, your goo will be mostly gone, and you can start cleaning up.
And I hope I don't offend you, but Mel, we really can't help you 3x per day. You need to back off just a bit, please.
Update, pool is clear now. I did a final shock last night, which the pool held overnight. pH is up and hopefully staying there. All (most) of the leaves and crap are out of the pool. So after massive amounts of chlorine I think we are on the right track and might be able to swim this weekend.
