Chlorine kills algea, algae is just a plant that grows in water. I'd say it isn't the best in the world for your grass, but if you could run your drain line into some woods or a drainage ditch you should be ok. I'm luck enough to have a drainage stream and woods right near my filter so I just drain out there as needed.
