Re: No questions yet, but sure there will be
Followed your directions, pool is much better! Thanks!
Test kit will not be here til next week, so had water tested (sampled at noon)
Free Chlorine 3.0 ppm
Combined Chlorine 0.0 ppm
pH 7.0
Alkalinity 70 ppm
Hardness 275 ppm
Cyanuric Acid 30 ppm
Cu 0.0 pm; Fe 0.0 ppm; TDS 1000 ppm; phosphates 200 ppb
Add a couple of boxes of borax to your skimmer SLOWLY while the pump is running. Other than that you're fine. . . if those tests are accurate.
Pool is looking MUCH better. Will be Thursday before test kit gets here :(
. . . just make sure to maintain your chlorine levels.
