Re: spring prep and a new pool owner
Thanks for that Ben. Im still a little confused about lots of things but Im getting there. With the recommended stabilizer from Sam'S Club and my chlorine level is hovering at 7 ppm it seems the next few days will be a bit of an iterative process to get the chlorine levels down a bit while increasing the cya presence.
Unless Im mistaken it looks like my target is around 50 ppm of stabilize. An idea on what type of CYA increase an initial 4oz treatment i can expect?
mogwai
I think you are asking how much a 4 oz. addition of cyanuric acid will add to your pool's CYA reading? If that is correct, then the answer is about 3.5ppm.
