No luck here. Not seeing anything. :(
Pool store then, we'll figure it out. No Problem.
Found something.
Hgh stabilizer and conditioner.
Ingrediants:
Cyanuric acid - 96%
Inert ingrediants - 4%
Thoughts?
That'll do.
Thanks.
Adding it to cart.
I think I'm good to go home and get started.
Will hook up and start pump first and then add bleach and my160 lbs of salt. Will run pump for 48hrs.
Add stabilizer tomorrow?
It'll take a week for stabilizer to dissolve. How much CYA did you buy?
That's plenty of CYA.
Give the pool a good brushing to mix everything.
Start with about a pound - pound and a half of stabilizer, put it in an old sock or nylon and hang it in front of the return. Give the sack a squeeze now and again to help it dissolve. Wait till early next week (sock should be empty and K-2006 should be in your hands) and test CYA.
Keep chlorine around 5 in the meatime. Run your SWCG when it's ready but test every day and add bleach as necessary.
The amount of CYA you'll need depends mostly on how much sun your pool gets and how warm it is. This forum usually reccommends 40-50PPM CYA for manually dosed pools. Often, SWCG manufacturers recommend a CYA level (check your manual), it's usually best to run your CYA at the top of the manufaturer's range. Be sure to adjust your FC goal for your CYA level based on Ben's Best Guess Chart.
Let us know how it's going.
Tested chlorine this morning before leaving for work.
IT immed turned bright orange! Ooops. Am I correct in thinking that the orange color means the chlorine is really high? (prob 10-15?)
All I have in it is a gallon of bleach and 160lbs of salt so far. Nothing else. The SW generator has not been turned on yet at all.
If I leave the stabilizer out I assume the chlorine level will drop without to much delay. We'll see.
Is it possible that it is so high it could be hurting my liner?
Oh btw... I tested the pool twice (same result - both turned orange) and tested my tap water once just to be sure so I am pretty sure the test was not inaccurate.
