No, I'm not trying to push his information aside. I very much appreciate it. I agree that getting a downsized pump and running it on high most of the time is a rational plan.
The problem I see is that going too small won't allow me to get a decent turn-over rate.
I've been doing a little more research and it does appear that I can push a bit more flow that 42 GPH even though its not the best idea. Something on the order of 55 GPH or so.
The thought of using the booter line as a second suction line is very intriguing. That would be terrific if I can do it.
The port on the side of the pool is maybe 18 inches below the surface. Would this really work? BTW: The only reason I call this the booster/cleaner line is that what the previous owner called it and there is an unused booster pump in the pool house. He said he threw his cleaner away because it didn't work.
Can I have 2 1.5 inch suction lines and a single 1.5 inch return?
ALso, thanks everyone for helping me through this.
