PoolDoc
			Waterbear,
But, something you said seemed to suggest that there may actually be a 5th category: non-concrete spa attached to a non-concrete pool. Are there such beasts?
Yes, I have a fiberglass pool and acrylic spa myself.  However, there is emprical evidence that higher calcium in a fiberglass pool helps inhibit staining so I run my calium acording to the SI recommended for plaster. Since doing so I have had no staining.  If I let it drop the fiberglass yellows and I have to break out the ascorbic acid.
The hydrogen bubble thing you mention is something I want to leave alone for the moment.
Yet, this is the main reason to run CYA at max in a salt pool.  It does slower the pH rise from outgassing of CO2.
 Also, you describe buffer action in ways I wouldn't, but again, I'd like to leave that for later.
Just trying to put it in terms that the ordinary reader would understand,  It is a difficult concept to grasp properly and there is just not really a good analogy that I have been able to come up with.  Chemgeek's spring analogy is good but even he said that it was not really right and I do agree.
A point of curiousity: who IS poolspaforum.com? I was surprised to find that they've elected to use anonymous domain registration, which is unusual for businesses on the Internet.
They publish a pool/spa magazine with paid advertising but the forum is pretty much on it's own except for the mods (and as far as I can tell there are only two of us active) and a lot of experimentation with methods of spa care (way beyond the usual dealer's "drop a few bromine tabs in a floater and forget about it") and some workable spa care methods have come out of this, mainly dichlor/bleach, 3 step bromine (sodium bromide to create bank AND tabs in a floater) with bleach as the oxidizer, and silver/MPS/hot water such as N2 Spa (the pool N2 is a different animal altogether) and Silspa from Njonas.
You wrote
Ok by me -- this is POOLForum, not PoolSpaForum. There are many more pool and more spa owners out there than PF + TFP + Havuz + PoolSpaF can serve, all together. (The shortage is in "answerers", not "askers"!) I'm willing to add spa help here, but I have ZERO desire to be a primary destination for spa owners.
However, the OP that started this all is not a spa owner but really a pool owner with a high aeration pool and a SWCG, different animal than a spa owner! Let's remember this fact.bold type for emphasis
Also, reading through your post leaves me convinced that it's STILL not possible to provide people a "SpaSolution" that parallels, in quality, the "PoolSolutions" I developed. Since there are still unmet needs in the pool arena, that's what I'd prefer to focus on.
Thanks for the clarification on spa/pool arrangements. The shared water arrangement is the reason I have to change my attitude. It's seems to me that this configuration is, essentially, a pool with extra aeration, which you note.
There is one sanitation aspect to this layout: with low CYA/low Cl, the total mass of FC in the spa is not necessarily enough to oxidize the total mass of swimmer goo (if say, 4+ people get in, and the water is hot). This would result in a failure to sanitize, since the chlorine present would be reduced by the goo, leaving insufficient FC to rapidly kill bacteria and viruses shed by one or more spa users.
The very high turnover rate would ameliorate this issue to a degree, since fomite associated bacteria and viruses would end up on the filter, leaving only planktonic pathogens present in the water.
Are you aware of any downsides to using DE in this setup? Doing so would improve sanitation, I think.
No, and many installations do have a DE filter.  I have a Cart myself.  However, as you noted, in spa mode the turnover rate is very fast (I have a 150 sq in filter and 1 HP (full rated 2 speed) pump on a 280 gal spa! Once the system is put back into pool mode the water is basically dumped from the spa and into the pool.
Also, the SWCG is active in spa mode and runs at a lower output percentage (because of the automation). Not all systems allow this but many automation systems do. Simpler units such as the Pool Pilot (correct me if I am wrong, Sean) and the AquaRite used with manual valve sonly chlorinate in spillover mode because they lack the abiliyty to have two different output settings for pool and spa mode.
If we are talking about a manually chlorinated pool/spa then you are correct that the santizer will be depleted as the soak continues but this is really no different that what occurs in stand alone spas and, once again, the water will be 'replaced' after the pool is turned back on.
So far, having read some of Richard's stuff at TFP and elsewhere, and having read through your posts, I'm still inclined to say the best approach to take at PF, with respect to spas is:
 1. Hi CYA + Hi Cl
 2. Relatively low TA, composed of borates, cyanurates, and some carbonates, with VERY low CA.
 3. Optimal pH at 7.8 - 8.2
 4. Calcium adjusted to avoid scaling in the heater, but to bring the SI high enough to avoid plaster damage. However, on non-concrete setups, calcium can simply be left low.
 5. Preference given to recommending DE filtration (unless you know a reason not to do so)
 6. Caution given that HiC2 might void warranty, BUT they won't know unless spa owners tells, and that there's no reason to suspect that HiC2 damages anything.
 7. Finally, when all is said and done, recognizing that spas cannot generally be as stable or sanitary as pools.
 8. And, if "you don't want HiC2, go talk to Waterbear at PSF, and he'll explain other methods, there".
I feel like we need to offer pool owners the BEST method of sanitizing and managing their pool, not the one most acceptable to the Powers That Be. That's a call I made a long, long time ago when I started PoolSolutions, and not one I see any reason to change.
I agree but you have to take into consideration pool/spa combos with or without SWCGs which really a a different animal than say a vinyl ingound or above ground pool and require a different approach because of some of the uniquie problems these pools have with pH stability.
Of course, if there's some reason why HiC2 is NOT the best way, I need to understand that.
