There's nothing magic about liquid chlorine or bleach -- it's just one of the two forms of chlorine available to you that has no stabilizer. The other is cal hypo (calcium hypochlorite) and it's becoming increasingly difficult to find.
You could also use an SWCG (Salt Water Chlorine Generator), but that's significant expense upfront, and there's ANOTHER learning curve you have to climb with those units.
Here's an option: with your CYA that high, once you get your K2006, you can do this:
1. Dose 1x per week to 12 - 15 ppm chlorine using bleach. (We'll help you figure the dose, if you can give us pool gallons AND pool dimensions (so we can make sure the gallons figure is in range - often, it's not.).
2. Adjust your TC feeder / floater / what to trickle feed, so that your chlorine doesn't go below 3 - 5 ppm, before your next bleach dose.
That way, you can 'sneak' in, dump the bleach, trash the bottles, and then bask in the appreciation for the crystal clear pool (assuming, your filter is working OK). Over time -- depending on how you clean your filter -- your CYA will drop. The more pool water you dump (backwash) each time, the sooner it will drop. If you've got a cartridge filter, and don't loose any water, you may have to see how things run this way and whether the CYA keeps climbing.
