Regardless of how small of an amount you add, when you are at the bottom of the scale, you can be past 6.8 and not know it, hence my caution.Quote:
Originally Posted by waterbear
Michael
Michael
I agree with Carl and Michael. Stop at 7.0. If your kit says 6.8, it could actually be lower than that.
Hope this is helpful!Quote:
Originally Posted by Sigrid
Good morning!
After dropping pH to something less than 7.2 last night and aerating overnight, I tested this morning at 7.5 pH and Alk at 130! That looks like progress and I'm delighted.
Waterbear, if I understand correctly, I can actually trust this alk number because the pH already went up, right?
I'm hoping that's the case. I just put in another 1.5 gallons of muriatic and will be aerating all day. Targeting alk in the 80-90 range (high alk fill water, heater).
Everyone, thank you so much for all the help and sharing your insights with me!
--Sigrid
Do I circulate water (along with aeration) after applying Muriatic Acid or do I pour it in the deep end and let it sit idle for 6-12 hours as others say? I'm confused because they are totally contradicting directives. Thanks
Circulate immediately. The so-called "acid column" method is pure hogwash and will damage your pool.
Michael
I agree with mwsmith2....the 'acid column' is supposed to cause carbon dioxide to gas off much like pouring acid on baking soda causes it to fizz. I have even read descriptions of it that says you might see bubbles of CO2 form and rise to the surface but that just doesn't really happen. The problem with that is carbon dioxide is very soluble in water and unless you airate the water to drive it off it tends to stay in solution. Carbon dioxide in water forms carbonic acid (think club soda....exactly the same thing). To drive the CO2 off you shake the bottle of club soda (or airate your pool!)
hope this helps.
Very nice analogy, thanks!
