Re: First time closer
		Hi Eric,
Sorry I didn't get back sooner but it has been busy here the last couple days compliments of Irene. Right now I'm on generator and with all the outages around here I may be out for a while. I got it easy compared to most on the east coast.
I also don't cover. Used to with a Looplock but with the constant snow, melting, refreezing etc I would wind up with a cover frozen in a big block of ice with the springs stretched so I don't bother anymore. I keep the equipment going as long as possible and open as early as possible. Don't use polyquat or anything except a good shot of chlorine and raise the pH up with borax. By the time I winterize all the leaves are down. If I procrastinate in the spring I do go a little green but that's easy to remedy. I also don't drain below the skimmer bottom and have a pretty tricky setup with a couple small pumps on the shallow end floor so I can actually drain some with the block of ice present and do no damage. I plug the returns with non-protruding caps so nothing sticks out for the ice block to grab and damage and one of the small pumps melts the ice around the steps so I don;t crush them. Usually don't have to drain though. As for filling in the spring I have a small stream that works well....free water.
That's about all I do.
Any more questions just ask.
		hmmmm...I bet I'd end up with the same block-o-ice cover, since we do alot of freeze/thaw here too.
"don't drain below the skimmer bottom"  = your pool water level *is* below your returns, at least?
I don't have 'smooth' return plugs...I should get some of those....but, the return pokes out (kinda) anyway, so is it that much of a problem?  I'm not going to be pumping water out (with a block of ice still in there) since it'll *all* be frozen solid anyway...that block won't be moving anywhere to be yanking on the returns.  Enlighten me on this, if you think it's valuable...
I'm thinking I'll just drain below the returns...yank *all* my plumbing, roll it up, and put it in the shed.  This means the skimmer bottom will be open to atmoshere and the returns will be holes in the side of the walls.  I'll tube short backwash hose to the returns, so overflow can spill out, away from the pool.  The pump will be drained and sleep in the shed.  The De filter will be cleaned, drained, in/out fittings capped (and 'maybe' sleep in the shed...since I have to take it apart anyway to clean it...might as well ship the 3 pieces into the shed).  the multi-port will be dained and sleep in the shed.  During the 'never-never' times, before the 'real' solid freezing starts...I'll drop my submersible in there, sideways, just to spin the chlorinated water around.  it'll take seconds to yank that pump out..once the real freezing begins...mid-late december.....reverse the process, once thawed enough to get the subersible back in....(I'm too chiken to let it freeze in there)...
gotta scram...time to go home
		Eric - Welcome to the Forum!
I like the cut of your jib!!! You Have a great sense of humor and understand our "Americanisms" (though you're an American too -- I had a room mate from Canada and he liked to point out that he was also an American [Canada, last time I checked, is in North America] ;) )
I think you've found what you ought do - thanks for joining us and - if it's feasible, join us over the winter to share your humor and hang out to talk about pool stuff 8)
		<giggle> thanks, Ted :o
The pool is new for me and I'm glad to have found a bunch of great people who are intelligently enthusiastic about their hobbies.  It makes for good discussions.  I look forward to posting, on the few threads I'm involved in.  I just wish I could type faster!
		My experience has been during winter that either I'm a slave to my cover or a slave to my pool water, and being surrounded by so many trees (pines, oak, etc.), I find I'd rather maintain a cover.
I use the Rule automatic pool cover pump ($140 and it lasts a number of seasons).  If big rains are predicted I just flip a switch and it's ready to go when it senses water.  I've a 300-ft. garden hose attached to it that winds down through the lower yard, under the privacy fence then runs along the 2nd driveway, well-hidden by leaves, and ends up at the curb.  That way when the pump is evacuating copious amounts of rainwater, it doesn't drain onto my property (or ultimately my neighbor's).
During the very long leaf season I regularly (weekly, sometimes daily if I don't like looking at it) either rake, blow or use my long pool pole with an old pool brush to push/pull debris to the edge and up where I dispose of it.  That way the pool cover pump also doesn't get clogged by debris (well, it still does but I just quickly clean the screen to it).  Yes, this goes on for virtually 8-9 months, because in the spring there is just loads of junk coming down from budding trees as well.  So...there's never standing water on the pool cover and it doesn't get nasty at all.  In May it just takes a warm day or two after the last rain to completely dry before a friend and I employ the sailor technique to remove it (folding one large lap onto the next until it's out of the pool and then rolling it up for storage).
Also, I can monitor my CL during the entire time by pulling up a flap I made over the skimmer with some scissors (and a lighter to seal the edges of the cut cover edges of the flap) and if I need to add any CL I just put it in the skimmer and run the pump awhile.
Because I have continuous double-tubed water bags around the entire circumfrence of my 16x32 in ground, unbelievably when I open 9 months later, not only is the water as clear and pretty as it can be, but at most there might be a silver dollar's worth of grit in one corner of the deep end.  The alternative to all this would be looking at my pool become very, very dirty -- beyond imagination, really, despite heroic attempts to keep it clean - in fact, it would be impossible in my environment to do so.  No worries!
		With my inground pool the ice never forms right against the edges for some reason. Close but there is room for my return plugs and the skimmer faceplate. The plugs are homebrew from PVC pipe plugs cut off to be real short so they son't stick out.
		Ah.  I get it.  I've got some of those pipe plugs too.  But, I'm thinking of leaving the returns open to drain through, so I won't plug them.
