Re: Start-up with chorine after 2yrs of Baqua-yuck
I can't imagine you added enough copper to turn things green that quickly with dual action pucks. From your post it seems like you only used a few. More worrisome is using pucks in your skimmers, I know folks who have caused real hardware problems from "burning out" skimmers. I use Cal-Hypo (73%) to shock on opening. 15 pounds. Gets me to 50ppm. I keep CYA between 60 and 75. I open early (colder) and just don't think about anyone getting in the pool for 10 days at least. I find this the easiest and my CH always stays just fine, I use BBB completely otherwise. I think of shocking just like Z Pack. The nuclear option. I close with 25+ ppm and that CYA, figuring on keeping Cl until the temps drop. My pool has never been better since finding the Pool Forum.
PBLsQuad450
That's what we like to hear! Good to see you back on the forum for another season.
Watermom
Glad to be back. Question on that though, I don't see references to joining or anything anymore? I would like to re-subscribe/support PF. Been here a year, and this years start up has cost so little, I promised to share last year so..
Here are test numbers from this morning (Thursday):
FC - 6.5
CC - .5
pH - 7.6
TA - 130
CYA - 0
After a week I still don't have stabilizer registering. I finally had to do a backwash last night, because circulation had slowed down. Heavy load of swimmers and sun over the holiday weekend. To the point where I couldn't get the FC to register on Tuesday evening. Shocked with 5lbs of cal hypo (49%) Tuesday evening. Another heavy load of swimmers Wednesday (kids are out of school), so I shocked again Wednesday night, this time with six 3/4 gallon jugs of 6% (s'what the wife brought home from Target). I'm guessing I need to pick up another bottle of stabilizer and see if I can get it dialed in. Today is cloudy, so I may have a day without swimmers, to get the chemistry right.
Your stabilizer would be dissolved by now. In a pool this size, 4lbs. of stabilizer should have added about 20ppm of CYA which can't easily be read with the tester. Go ahead and add another 4 lbs. and give it a week to dissolve. That should take you up to about 40ppm or so which would be a good level.
